Quote:
Originally Posted by kylerwho
what is the t1r man. trans . kit? you might need a new clutch for the more power layed down. at what point do you need to upgrade the octane points when upping your boost? i know you need to run 92 for the t1r kit @5.7 lbs. will you eventually need to jump up in octane points as your boost increases to prevent detonation?
T1R makes a manual transmission turbo kit, and a automatic transmission turbo kit.
The auto kit made about 10whp less than the manual transmission kit.
If you have your car properly tuned to 91 or 92 octane then you should be fine. If you just increase boost without properly tuning then running a higher octane could help, but its not the proper way of doing it.
