Quote:
Originally Posted by fad3r
Well, after much searching around on the boards and on the net, there doesn't seem to be too many fat lipped 15" wheels around that have a +55mm offset. Most are +38, +40, +42. I've seen a few +45mm offset 15" rims, but I'm worried they'd rub.
37 to 47 is fine for the Fit... If you go w/ wide rims, you need to reduce
the offset or the tire could rub on the inside (like rubing the suspention parts)
So, wider rim (7" or more) = lower offset (ex: +38)
The stock sport offset is 55 but the rim is 6" wide... to be in
the stock center w/ 7" wide rim, you need to reduce the offset.
(tire will be closer to the fender lip)
Philippe
__________________
VBP 2007 M\T Fit sport
Gram Lights 57s rims (15"X6,5" +43mm)
Yokohama S Drive tires (195 55 R15)
Fujitsubo Wagolis exhaust
OEM alu shifter knob
OEM floor mats
So shitty...
Flake Radioactive Obnoxious Green paint
