View Single Post
  #29 (permalink)
Old 11-03-2008, 12:20 AM
niko3257's Avatar
niko3257 niko3257 is offline
FitFreak GE8 DIY Guy
niko3257 relies on Rep Points to liveniko3257 relies on Rep Points to liveniko3257 relies on Rep Points to liveniko3257 relies on Rep Points to liveniko3257 relies on Rep Points to liveniko3257 relies on Rep Points to liveniko3257 relies on Rep Points to liveniko3257 relies on Rep Points to liveniko3257 relies on Rep Points to liveniko3257 relies on Rep Points to liveniko3257 relies on Rep Points to live
alright i'm back for a little. it's been a long day
well lets get started on the back of the car.
for this to be done you have to have the hole back
end of you car lifted. and not by the suspension.
so i began by lifting one side at a time by the bottom
of the spring. look at my picture and see where the jack is.
this is where i jacked each end up from and while up i placed
jack stands up.
now you should have both jack stands on the car and the wheels off.
before we go any further make sure you unhook you abs wires on
both sides.
now take your jack again and place it on the car just like in the picture.
right under the spring. jack it up like an inch or so.
then take off both bottom shock bolts completly. right and left.
after you have done that take your jack out. it will look similar to this.
all you do now is just give it a little push and wam both springs will
just pop right out.
now we can compare again. lets see.
very nice
