Pistons for the L15!!!!
Old Nov 5, 2008 | 02:28 PM
Bassplayer's Avatar
I was searching around ebay and found that CP Pistons has come out with aftermarket pistons for the fit, this was new to me! 9.0 comp should be great for turbo applications. Now all we need is someone to develop rods and head studs and then we can have a built fit motor and maybe push some big numbers out of the little L.
Here's a link: eBay Motors: CP Pistons Honda Fit Jazz L15a Vtec 73mm 9.0:1 SC7037 (item 300270865095 end time Nov-10-08 09:38:05 PST)
Old Nov 5, 2008 | 02:44 PM
gd3kamiwanaB's Avatar
Luvs Dah b00st!
good find but old news ,rods arent that important i plan on getting these pistons and having my rods shot peened
Old Nov 27, 2008 | 09:46 PM
040501912's Avatar
try to find topfuel japan.. they do have the forged internals for their car.
Old Nov 27, 2008 | 09:51 PM
kylerwho's Avatar
spoon fed
forged internals are not what is important. trying to figure out a way to open up the little L series motor ports is what will unlease the real power. the head is what is restricting all our power.
Old Nov 27, 2008 | 09:52 PM
kelsodeez's Avatar
UNBANABLE
i wish someone would try to swap a ge8 head onto a gd3 low end.
Old Nov 27, 2008 | 10:16 PM
kylerwho's Avatar
spoon fed
hmmmm....... i can aquire the gd3 lower half if anyone is willing to ship the ge8 head.
Old Nov 27, 2008 | 10:31 PM
kelsodeez's Avatar
UNBANABLE
if i had one, id donate it. there has to be a GE8 owner around here that has done a K swap.
Old Nov 27, 2008 | 10:38 PM
kylerwho's Avatar
spoon fed
im searching for a wrecked ge8. if i can get my hands on one i can run wall thickness tests and see how compatible it is with the gd3 L motor. is there any way around the exhaust system though? any pics?
Old Nov 27, 2008 | 10:55 PM
kylerwho's Avatar
spoon fed
this integrated exhaust/cylinder head looks prime for a turbo to be bolted right up to it.
why cant this whole unit just be replaced with a straight pipe? anyone willing to drop off their ge8 for me to build one?
look here for more info.
Honda Media Newsroom Release: 2009 Honda Fit - Powertrain
Old Nov 28, 2008 | 04:01 AM
040501912's Avatar
I would like it BUT im not in US lol!...
its very annoying how they designt the exhaust system...
Old Nov 28, 2008 | 09:05 AM
underdog's Avatar
they make a turbo kit for the r18 civics with just an adapter for the turbo and dowpipe. it can be done. just have to find someone who can/wants do it.
Old Dec 1, 2008 | 06:40 PM
eldaino's Avatar
i think that porting is next to impossible is it not? i've heard that thats the biggest limiting factor as well. i do doubt anyone has done a kswap to a ge8 yet though, its too new. at least in the us.
Old Dec 1, 2008 | 09:09 PM
kylerwho's Avatar
spoon fed
someone already has put a k20 in the ge8 chassis and it fits better under the hood.
i will try find pics
Old Dec 2, 2008 | 12:08 AM
dewthedew's Avatar
im pretty sure the head doesnt bolt up to the gd3 lower end.
Old Dec 2, 2008 | 12:31 AM
dewthedew's Avatar
so the only interals that are avail. for the fit are pistons?
Old Dec 2, 2008 | 01:31 AM
kylerwho's Avatar
spoon fed
the only production parts. custom pieces are always available to those with deep pockets.
Old Dec 2, 2008 | 11:56 AM
Bassplayer's Avatar
Has anyone seen a Fit with pistons in it yet? I'd assume you'd be able to crank up the boost a few psi with the lower compression and make a couple more horses safely.
Old Dec 2, 2008 | 12:23 PM
Nabisco's Avatar
Senior Member
I want to see the compression ratio retained on the forged pistons!
What about rods? Why is this taking so long?
Most Honda rods that I have seen bend if you even look at them wrong!
I really don't see a very reliable 180 WHP without them.
Old Dec 2, 2008 | 08:21 PM
kylerwho's Avatar
spoon fed
kelsodeez is making 175hp realiable. the rods are very strong. j's racing is running high compression pistons in their track l15a jazz. there is a member in the philipines who has sleeved the block and is running forged pistons and connecting rods with the stock crank and is making just over 400hp.
Old Dec 2, 2008 | 10:25 PM
ghostfit's Avatar
I proposed this a while a while ago. The L series engine has the same stroke as the d16 and b18 series engines that have more aftermarket support for them. You could take aftermarket rods for a d or b series engine and with a little machine work, you could get them to fit with the l series crankshaft and pistons. Its been done with the d-series engines so why not see if it can work with the l-series engines.
