65000 miles, first major repair.
Hello Freaks, haven't visited in a while and thought i'd drop in a to report on my first major (non-scheduled maintenance) repair.
My 07 AT Sport started to hic-cup a but when i let off the gas on the interstate. When i came to a stop the car stalled. I got it to start with no trouble, then drove it home (i was 50 miles from the dealer and my office so home was my best bet at this point).
Next morning, low speed was problematic, idle was chugging hard and on the verge of stalling. I drove it about 30 miles toward the dealer and eventually the check engine light came on. I pulled to the side of the road and had it towed in for repair.
Turned out to be carbon build-up on the EGR valve. EGR valve took a freaking week to arrive, but once replaced everything's good again. Total cost was $302 parts and labor.
I can't believe i made it 65000 miles with nothing. I love this car
To give you an idea of my driving habits, i drive around 90 miles a day. 95% highway, hilly. I set my cruise for 72mph. Use regular 87 octane gas and change the oil when the car tells me it's time. Though, with the amount of driving i do, it's usually in the "negative" numbers before i get to it. Once the 10% and 5% life remaining lights are done, the car counts into the negative miles to constantly remind you to change the oil.
Interesting. Wonder if anybody else had this problem.
Anybody ever use Seafoam? My friend used this to clear up his engine and talked me into using it on my Civic. Supposedly it clears out gunk wherever you put it. I only sucked it through some vacuum tube in my engine somewhere. Started the car and revved it and saw a bunch of smoke come of out of the exhaust. Guess it cleared out some stuff.
Sea Foam
Sea Foam
Sea Foam
Sea Foam
i don't recommend seafoam. it may dislodge carbon build-up and deposit it in places where it shouldn't go.
you can remove and clean the EGR valve by hand. just use carb cleaner or throttle body cleaner and just clean out the carbon build-up. make sure you clean out the ports too.
or you can buy a brand new OEM Honda EGR valve online. they're not that expensive. and the installation is very easy.
vo1one
Dec 27, 2020 10:01 AM
allTRACway
Mar 11, 2016 04:06 PM
2012FitFan
Nov 11, 2015 07:51 PM
