05-25-2006, 10:39 AM
Quote:
Originally Posted by Chikubi
ok, so I understand what offset is, how it's measured, how it relates to the rim, but what I want to know is this -- the Fit's standard rim is 15x6 +55 offset, but the average offset for aftermarket rims is always much lower, i.e. the WedsSport SA90's on your site are a 16x7 +45. I've always been told that if you stray from the stock offset you have issues like bearing wear, torque steer, heavier steering, rubbing, etc., none of which I want. What I want to know is, how can you be using a lower offset wheel and not have these problems? Why are there no rims w/ a +55 offset like the stocks? If you go to a lower offset the centerline of the wheel is in a different place than stock, regardless of wheel width, so how does this not cause damage/handling issues? I really want to get some rims for my Fit, but not if it's going to ruin the handling, or even worse, cause damage. Can anyone clarify this for me? Thanks!
Well written. I was wanting to know that too. I am planning on running 17" and all of the wheels I am finding have offsets between +35 and +42.
