FS: LED products
Old Dec 19, 2008 | 03:31 PM
julianisjulian's Avatar
I want to get led's into my headlights but I'm not good with wiring and all that stuff
Would a first timer be able to set this up?
Old Dec 20, 2008 | 10:22 AM
Fit of RAGE's Avatar
the wiring itself isn't hard. the difficult part is sealing the headlight back up.
Old Dec 21, 2008 | 03:10 AM
before I make any decisions could you show make a write up for me so I'm not completely clueless if I do buy these?
Old Dec 21, 2008 | 05:30 AM
dewthedew's Avatar
when my gfs audi TT gets out of the shop i think i might get these and make some R8 style lights
Old Dec 21, 2008 | 02:44 PM
keepitpg's Avatar
i love college
howd you do the puddle lights on the side?
Old Dec 22, 2008 | 08:55 AM
Sorry, but i will NOT be doing a DIY on the R8 Headlights. Honestly, I want to be the only one with them. However, feel free to try it yourself.
I've got square LED modules with 4 LED's on them. I've got them drilled and taped to the INSIDE of the sideskirt and therefore, you can't see them.
Old Dec 23, 2008 | 07:27 AM
YA2_user_GD3's Avatar
Hey can u explain the installation a bit? Because I'm not familiar with any wiring so I want to see how practical the install is. Thanks!
Old Dec 23, 2008 | 08:47 AM
It's actually REALLY easy. WHat you've got is the LED strip with two prongs sticking out. Those two prongs connect to a wire harness (that is provided with EACH LED strip) There are also "+" and "-" signs all along the strip.
It's REALLY easy! You can't screw it up!
Old Dec 23, 2008 | 10:17 PM
Sounds good, where would I access the car's wire harness? I guess that seems to be the puzzling part to me, if I would need to take apart door panels or something.
Thanks.
Old Dec 24, 2008 | 01:06 AM
I connected them the same way i did this:
DIY: LED Door Sill Lights
Old Dec 25, 2008 | 01:58 PM
accordguyintake's Avatar
can you get a pic or 2 up on how to do the puddle lights? interested
Old Dec 25, 2008 | 03:34 PM
  #32
it's not that hard. all you have to do is take the body kit off and drill. It's super easy.
Old Dec 25, 2008 | 04:23 PM
  #33
yeah but likeee... where do u drill and stuff? hahah and how much for 8 (same effect as yours)
Old Dec 25, 2008 | 05:45 PM
  #34
well, what you need to do is:
1) take off the sideskirt
2) Space out 4 LED modules evenly
3) mark where they're supposed to be
4) either - A) tape and drill them on the OUTSIDE of the sideskirt (they will then be visible)
- B) drill 4 holes where the LED's will fit on the INSIDE of the sideskirt (they will NOT be visible)
The only way i can show you is if i do another set of them or take mine off. Seeing how it's snowing like a bastard here, i won't be doing any car stuff until it starts to warm up.
The LED modules will be $12/module + shipping
Old Jan 10, 2009 | 11:01 PM
  #35
sonicsc1's Avatar
how much for the headlight hid kit?
Old Jan 10, 2009 | 11:25 PM
  #36
Sorry bud, I sell LED's not HID's
Old Jan 11, 2009 | 04:04 PM
  #37
Syco54645's Avatar
How did you do the glovebox like that? Same way that the DIY says?
Old Jan 11, 2009 | 04:47 PM
  #38
DId i do a glove box DIY??? I can't remember if i did. But yes, what you have to do is:
1) Cut the LED strip to the proper size
2) Extend the wires (power and ground)
3) Find a CONSTANT 12 volts
4) Find a SWITCHED ground
- what i did was i make a bracket that screwed into the glove box dampner. Therefore, when the box is FULLY open, the light goes on.
Old Jan 11, 2009 | 05:19 PM
  #39
Syco54645's Avatar
I dont get what you mean here.
Old Jan 11, 2009 | 09:05 PM
  #40
If you open yoru glove box, you'll notice that it doesn't go BANG! There's a little rubber dampner. That dampner rests on a metal bracket. All i did was make another bracket that attaches to the dampner.
