GI: Direct Bolt-On Projectors!!
Old Dec 21, 2008 | 02:57 AM
  #41
jdmsneakerhead's Avatar
can't wait for pics, looking to put these in my 09 and maybe in my girl's mom's odyssey
Old Dec 22, 2008 | 08:55 AM
  #42
Fit of RAGE's Avatar
i'll get my set in ASAP.
Old Jan 6, 2009 | 11:07 PM
  #43
alright, i FINALLY got my hands on a set!!
Ill put up a DIY thread on it.
I do need to know how many ppl are interested tho.
Old Jan 8, 2009 | 01:23 AM
  #44
Im|Inside|Fit's Avatar
WOW thats really nice!
Old Jan 8, 2009 | 01:08 PM
  #45
These ones that I've got comes with absolutely EVERYTHING you need to complete the job.
- 2 Bi-Xenon projectors, clear glass lens, ellipsoidal reflector bowls (TSX)
- 2 6000K xenon HID bulbs for pure bright white output (12 months warranty)
- 2 DIGITAL GEN3 Smart HID ballasts (12 months warranty)
- 2 integrated white CCFL angel eyes, SUPER BRIGHT (white color)
- 2 Fully integrated universal wiring harness
- 2 Mounting/alignment projector bases - Instructions
- Sealant, splice wire taps, waterproof connection seals
Old Jan 8, 2009 | 05:23 PM
  #46
Crawly's Avatar
Can you get these for other bulbs? I'd like to get a set for my dad's new Accord lol
Old Jan 8, 2009 | 05:29 PM
  #47
yes you can, they are available 9 different bulb sizes H1,H3,H4,H7,9004,9005,9006,9007,H13 CE and UL safety listed, ISO registered manufacturing, E4, E11 TUV mark. All genuine parts are individually serial numbered
Old Jan 9, 2009 | 07:12 PM
  #48
https://www.fitfreak.net/forums/fit-...ctor-lens.html
PRICES ARE ALSO SET
CHECK OUT FIRST THREAD
Old Jan 10, 2009 | 02:05 AM
  #49
here's the DIY if you want it:
Originally Posted by Fit of RAGE
Alright everyone, it's done!!
Here's the DIY for the Bolt-On Projector Lens that i'm selling. After I installed it, I can truly say, that it's REALLY easy!! I did the entire job in 2 hours...including dissembling the headlight!!
Firstly, follow this thread on dissembling the headlight:
https://www.fitfreak.net/forums/fit-...rojectors.html
1) here's the headlight without the lens
2) you have to remove the bulb holder spring and the reflector...thingy???
You have to remove it from the back end.
3) Here's the headlight now:
4) remove all the spin locks, springs and washers from the projector unit. REMEMBER WHERE THEY GO!!!
5) Find out which side is the top side of the projector.
6) Feed all the wires through the FRONT of the headlight so that the Projector unit faces forward.
7) Put the locking tab back in place. IT ONLY GOES ONE WAY!
8) Now, put back all the spin locks, springs, washers everything IN THE RIGHT ORDER!
9) Guess what..... YOU'RE DONE!!
EASY!!!
Here's a pic of the Halo on:
Low Beam Cut-Off
High-Beam
(GB info is here: https://www.fitfreak.net/forums/gaug...jectors-3.html)
Old Jan 10, 2009 | 02:36 AM
  #50
Koi's Avatar
Koi
Requesting pic of car with halos on from further away.
Old Jan 10, 2009 | 04:16 AM
  #51
fitster's Avatar
common people
1. fitster
Old Jan 10, 2009 | 08:23 AM
  #52
FELIXY69's Avatar
it doesnt look like the bulbs come out of the projectors
can u chAnge them??
Old Jan 10, 2009 | 12:39 PM
  #53
The only pic that i've got is this one.
I didn't hook them up on mine because i've got the R8 lights. I felt that the Halo's and the R8's would clash.
can u chAnge them??
Yes you can change them. They do come out. They use D2S bulbs
Old Jan 10, 2009 | 01:12 PM
  #54
jtsimaras's Avatar
How is the back sealed as the stock rubber seal is not going to seal against the wires properly as the hole is much bigger to account for the thickness of the base of the H4 bulb.
Old Jan 10, 2009 | 01:28 PM
  #55
The back dust boot goes over all the connectors fine. I"ll grab pics later. Plus, the entire unit has it's own dust boots/seals anyway.
Old Jan 10, 2009 | 02:13 PM
  #56
FitVic's Avatar
So we can use our H4 hi-low hid kits that we have now with this projector. I just want to see how wide and far the beam is whenever you can take a picture in an open area.
Old Jan 10, 2009 | 04:22 PM
  #57
You can use your current BALLASTS only. Not the bulbs
Old Jan 10, 2009 | 04:26 PM
  #58
FitVic's Avatar
EDIT: sorry lmao I just read it. Kinda hard on the Blackberry Bold. Well just outside pictures and I'll see if I'm down for this
Old Jan 10, 2009 | 11:04 PM
  #59
wdb's Avatar
wdb
Subscribed. You've mentioned several times that people can use their existing ballasts. Does the kit come with EVERYTHING needed, including ballasts? It looks like it does, so I'm a little confused as to why you tell folks they can use existing stuff...
Old Jan 10, 2009 | 11:29 PM
  #60
Ppl were wondering if they can use their current HID kits. You can use everything except the bulbs. Wiring and ballasts are compatible with the projector kits. You can't UAE the bulbs because the projectors use a D2S bulb.
