View Single Post
  #47 (permalink)
Old 05-31-2006, 12:08 AM
kentris kentris is offline
Frequent FitFreak Poster
kentris is on a distinguished road
Actually, there's a much simpler method of removing the rear badge.
If you look under your rear boot handle, there's a small gap. Between that gap you should be able to see the 2 pegs that hold the badge inside.
All you need is a ruler with the little hole in it (which is normally used to hang rulers up in the shop) and then hook it and then pull down with enough force and the peg should snap off
