View Single Post
  #312 (permalink)
Old 12-31-2008, 04:37 AM
Ein's Avatar
Ein Ein is offline
Ein relies on Rep Points to liveEin relies on Rep Points to liveEin relies on Rep Points to liveEin relies on Rep Points to liveEin relies on Rep Points to liveEin relies on Rep Points to liveEin relies on Rep Points to liveEin relies on Rep Points to liveEin relies on Rep Points to liveEin relies on Rep Points to liveEin relies on Rep Points to live
Quote:
Originally Posted by Syco54645 View Post
The fit holds 10.8 or 10.9 gallons so the time to empty should always be off.
The point is to give yourself a little reserve. If you do rely on the Scanguage for filling up. The fuel light will go on long before the Fit uses up 10 gallons.
There is no point to set more than 10 gallons in the Scanguage. If you are not going fill up more than 10 gallons at the pump.
