Test: 2008 Toyota Tundra TRD
Old Jan 3, 2009 | 01:38 AM
Sid 6.7's Avatar
Why so serious?
We don't do much performance testing of the vehicles we review here at Autoblog, partly because we don't have the resources and also because our seat-of-the-pants-meter usually gives us the pertinent information we need about how a car (or truck, in this case) performs. There are times, however, that we do get the urge to get real, actual numbers. Take, for instance, this 2008 Toyota Tundra TRD. Last month, Motor Trend put it to the test and claimed it could muscle its way from 0 to 60 mph in just 4.4 seconds. While we have no doubt that this time could theoretically be achieved assuming unlimited amounts of traction, we called shenanigans and vowed to get our hands on the truck to record our own numbers. Fortunately, Toyota was game and provided the same exact Tundra TRD used in Motor Trend's test with a fresh set of rear tires. We're not here to debate the point of a performance truck or argue with those who think vehicles like this are the cause of global warming. We just want to see what it'll really run. So along with our pal Mike Levine of PickupTrucks.com, we set out to play drag racer for a day and find out. Read on to see the results.
The Goods
First thing's first. What's the deal with the Tundra TRD? While you won't find one listed for sale on Toyota's website, you can actually order a Tundra with most of the TRD parts from the factory and have the remaining bits installed through a dealer. All TRD parts are covered by a factory warranty, meaning you can have your aftermarket fun and not have to worry about a dealership denying warranty claims.
Our tester came fully accessorized with the high performance brake kit, cat-back dual exhaust, 22-inch forged wheels wrapped with Toyo Proxes S/T tires, and a beefier rear anti-roll bar. Oh yeah, and a supercharger. The Eaton Roots-style blower pushes 8.5 pounds of boost into the 5.7L V8, yielding 504 horsepower and a tire-shredding 550 lb-ft torque. Along with the supercharger, the kit comes from TRD complete with a new intake with a reusable filter, high-flow fuel injectors and fuel pump, intercooler, Denso Iridium spark plugs, a retune of the ECU, and all necessary plumbing and hardware. Did we mention it comes with a factory warranty?
The Venue
With keys in hand, we made a beeline for Irwindale Speedway, or "Toyota Speedway at Irwindale" to be more precise. Southern California's most popular 1/8th mile drag strip is coincidentally sponsored by Toyota, and some well-placed signs at the track made for some unexpectedly great photo opportunities.
Whether it was the name on the back of our truck or just the politeness of our phone call, we were allowed free reign at the strip a half hour before their Thursday evening test-and-tune opened to the public. The track was very well prepped and the sticky pavement was a better launching surface then we'd ever find on the street. Our thanks go out to Bob Klein, the track's director of operations who helped make things happen.
The Results
While the facilities at the track included timing equipment for the 1/8th mile, we were mostly interested in the 0-60 mph time. To record our data, we used a Passport G-Timer GT2 from Escort that provided us with consistent data over several runs. We made a total of eight passes with Levine behind the wheel, and as you might expect, we initially had trouble finding the best way to get the tires to hook up.
The first run involved plenty of rubbery smoke and hitting the rev limiter, as the tires feebly attempted to transmit torque to pavement. With 7.50 seconds showing on the display, we headed back to the starting line for another attempt using lower rpm's at launch. The second pass went much better, although still with plenty of spinning tires, yielding a time of 5.55 seconds. After letting some air out of the tires and fine tuning the launch to include a short rollout to maximize traction, we slowly worked the times down – 5.45, 5.32, and finally a 5.20. We believe the Tundra TRD had at least another tenth or two in it, but a line of 50 drag racers were anxiously waiting in line behind us and our time was up.
So can the Tundra TRD hit 60 mph in 4.4 seconds like Motor Trend says? Providing for altitude, temperature, and humidity adjustments and a John Force perfect launch... we doubt it. The supercharged V8 has sufficient horsepower and enough torque, but traction is most definitely the limiting factor. If we were to perform the test again we'd bring a tire pressure gauge and weights to stuff in the bed, but we still don't think we'd break into the fours. So yes, the Toyota Tundra TRD will lose a drag race to any of the world's modern day supercars, but our seat-of-the-pants-meter says it's still one hell of a fast truck.
If you liked this story, click over to PickupTrucks.com for Mike Levine's account.
Old Jan 3, 2009 | 01:45 AM
Sid 6.7's Avatar
Why so serious?
Says Angus McKenzie of Motor Trend:
I have no idea why Autoblog wants to call BS on our test numbers, but I'm happy to supply the facts:
1) As per our standard procedure, we ran on an unprepared surface, with factory tire pressures and a full tank of gas.
2) Test driver Scott Mortara did eight runs, recording a worst of 5.6sec and a best of 4.6sec, uncorrected for atmospheric conditions, and with a one foot roll out
3) The one foot roll out is a legacy of more than 50 years of quarter mile testing, dating from when we started on drag strips. It is a uniquely American procedure, but one used by all our rivals who regularly test, and is widely recognized. Depending on vehicle it gives a 0.1sec to 0.3sec advantage over the standing start time.
4) Scott's best time came with the traction control on its minimum setting to manage the wheelspin, and by manually shifting the transmission. Sometimes the fastest way isn't the most obvious.
5) Our test day was hot. The standard atmospheric correction factors - applied to all our test numbers so they are comparable - improved the raw numbers.
6) We do not use windscreen mounted accelerometers to measure anything, as we have found them to innaccurate, and unable to produce consistent data.
We have been performance testing vehicles a long, long time. It's what we do every week, and we follow a strict regimen. I stand by our numbers.
Old Jan 3, 2009 | 02:08 AM
doctordoom's Avatar
Supervillain
i always like your posts. thumbs up
Old Jan 3, 2009 | 01:55 PM
08fithappy's Avatar
i love this truck i want one so bad almost traded the Fit for one. But than i saw the price tag on it and how the MPG was. And all i saw in my mind was $$$$$$$ so i kept the fit. Nice truck though for sure
Old Jan 3, 2009 | 02:34 PM
rvall004's Avatar
haha thats one bad ass tundra!!!!
Sid 6.7
Jan 4, 2009 12:43 PM
Sid 6.7
Jan 3, 2009 01:51 AM
Sid 6.7
Aug 19, 2008 08:48 PM
Buck
Jul 17, 2008 01:26 PM
robwahoo
Aug 21, 2007 11:16 PM
