View Single Post
  #5 (permalink)
Old 01-06-2009, 09:52 AM
NIGHTHAWKSI NIGHTHAWKSI is offline
NIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to liveNIGHTHAWKSI relies on Rep Points to live
nice thread.
what happened to your first build? what did you do half assed that caused it to fail?
what hoses are you tapping into to get the vacuum source for the BOV and your boost gauge?
btw, im using a turbo thats very similar to taht and i cant get the damn exhaust side free from the center to clock it properly. ive tried wd40, pb blaster (let ti souck for about 15 hours) and a blow torch...nothing has worked.
any ideas?
the oil return fitting is about 45* away from sitting vertical and im afraid that since its gravity fed it wont drain properly like that....
__________________
RIMS FS:
http://www.fitfreak.net/forums/sale-...tml#post772926
HID FX45 retrofit/JDM LED tail lights/JDM sunvisor/JDM red H's/AVIC-D3 navigation/Alpine type s/ MTX amp/MUGEN visors/Progress lowering springs/WORK CrKai 15x7 +44/Kics r40 neochrome lugs/RAYS valve stems/Aspec intake/Password JDM CF engine cover/Skunk2 short shifter/ARC shift knob/JDM yellow fog lights/Progress rear sway bar/fujitsubo cat-back
