View Single Post
  #2 (permalink)
Old 01-12-2009, 05:13 PM
manxman manxman is offline
manxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to livemanxman relies on Rep Points to live
Nice work on the deflector. Here in CA in non-snow areas, we don't have such a severe problem as you guys in the Frozen North. But Honda should resolve this problem at least in the next production design.
There is another solution and it does not cost much. Most auto accessory vendors carry a supplemental defroster that plugs into the 12 volt outlet with a fairly long cord so that you can set the unit on your dash to blow hot air on the windshield. You should not have to go to such lengths to be able to see in cold weather, but until Honda corrects the problem, this is another solution.
