View Single Post
  #20 (permalink)
Old 01-14-2009, 06:52 AM
Fit_Dr's Avatar
Fit_Dr Fit_Dr is offline
Fit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to liveFit_Dr relies on Rep Points to live
Quote:
Originally Posted by chyperX View Post
Interesting, I was told that going 205 on the standard rims would give side ways roll under reasonable cornering, and would comprmise the handling.
Depends on the air pressure you use in the tire.
I have a 205/45/16 on my 08 on a 6.5" rim and at first used 33psi all around but found the performance tires didn't like this low pressure at all. Felt like I was driving in sand and it was clear I was going to have uneven wear issues. I adjusted my pressure to 46 psi up front and 35 psi rear which is giving me better mileage, grip and wear. Your psi settings will vary depending on tire but will almost certainly need to be higher than the stock tires if upgrading to sticky rubber.
__________________
08 SSM Fit Sport MT/SSR Type C wheels/ Muteki blue lugs/ Bridgestone Potenza RE760 Sports 205/45/16/ ASpec axel back exhaust/ Luminics Krypton Pure Blue fogs/ Brembo sport slotted rotors/ Porterfield R4-S brake pads & shoes
