Enkei Rpf1 offset +35 or +41?
Old Jan 21, 2009 | 01:40 AM
fitinfit's Avatar
Originally Posted by raton
Just picked up the RPF1 15" (41 offset) on Dunlop Star Spec (195/55/15). On Skunk2 ProCs. No rubbing.
offtopic, how much more can you lower with the Pro-C in these pictures on the 15's?
Old Jan 21, 2009 | 02:37 AM
raton's Avatar
I'm sure I could drop another 1/2 inch or a little more front & rear. Not sure if it'll rub though. I've got -2.5 camber on the front w/ camber bolts so it helps avoid some rubbing. The current height is so I don't scrape my driveway everytime I go home.
I never tried the max drop but u could probably go even lower.
Old Jan 21, 2009 | 04:01 AM
feared's Avatar
car looks sick, good job
Old Jan 21, 2009 | 09:11 AM
mahout's Avatar
Getting some wheels, Enkei Rpf1 15x7, anyone know which offset is better? I see most people got the +41, I'm just curious if the +35 would work as well(clear stock calipers?)? probably look better? Thanks in advance!!
The v41 offset works without modding the fenders and has as much performance as the 35. Most have to use narrower tires with the 35 so looks aren't diiferent enough to tell at 10 yards. Performance may be better with 41's and wider tread on lightweight tires.
Old Jan 21, 2009 | 09:36 AM
rvall004's Avatar
u have to go with the 35 offset they will look 10 times better thatn the 41
Old Jan 21, 2009 | 10:48 AM
dewthedew's Avatar
any pics of the +35?
Old Jan 21, 2009 | 12:29 PM
rvall004's Avatar
^^^chek jerome's car he has 35 offset..his username is boris..something i forgot
Old Jan 22, 2009 | 09:36 PM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
my sig ...
Old Jan 24, 2009 | 10:57 PM
wdb's Avatar
wdb
I ordered the '02-'08 Honda CR-V center caps (#44732-S9A-A00, CenterCaps.net - Cap Listing - Honda Details - CR-V). Hopefully, they'll work ok. If not...meh...
Subscribed to find out the answer -- please let us know.
Old Jan 24, 2009 | 11:06 PM
dewthedew's Avatar
Originally Posted by BoriJDMGD3
my sig ...
looks good any bigger pics?
Old Jan 25, 2009 | 02:45 AM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
thanks, Ray have them on his camera...
Old Jan 25, 2009 | 09:09 AM
  #32
Tork's Avatar
Originally Posted by kenchan
i would do +41 on the front and +35 on the rear for a nice flush look.
+35 sticks out too much for my personal tastes, plus more potential for rubbing.
Agree with Kenchan except an option would be go +41 all around and use 5MM spacers on the rear (5MM are usually cheap) Keep in mind your stock wheels are +55 so 41's push your tires out about 5/8ths of an inch.
Old Jan 25, 2009 | 11:14 AM
  #33
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
35mm wont stick out!!! and it wont rub, if you put a 41mm and 5mm spacers you will have less thread in your lug studd... and it will almose the same thing ...
Old Jan 25, 2009 | 11:30 AM
  #34
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Ive ran +26mm... The tires are just inside the fenders and rear 1/4's. Yes it rubs a lot.
+35mm wont stick out at all.
It may rub a little, nothing the fender lining mod wont fix.
Heres Jeromes car.
Do a search on my name. My car is as low as itll go on Pro-C's.
I hit frame on some parts of the road.
Old Jan 25, 2009 | 11:00 PM
  #35
feared's Avatar
that's actually not a bad idea, looks almost the same but you can still rotate your tires... i may look into this haha
Old Jan 25, 2009 | 11:21 PM
  #36
YeeFit's Avatar
I beg to differ.. You might not rub going in a straight line but once you start cornering you'll rub guaranteed. I'm running +41mm and I rubbed a lot. 195 series tires too. Those that say you won't rub either must not be lowered at all or never have to turn.
I rubbed a lot in the front and never in the back when I was lowered on TEIN S-Techs (1.8" drop)... but then I swapped those springs out for the J's Racing/Showa suspension (1.0" drop) and i rub a little in the back with passengers.
Old Jan 26, 2009 | 06:18 PM
  #37
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
i do cornering too, and i have 195/50/15 and still no rub ... and im sure my car is lower than 1.8 drop, on lowering springs.
Old Jan 26, 2009 | 06:23 PM
  #38
YeeFit's Avatar
well that's a bit of a discrepancy then isn't it?!? lol.. perhaps the 50 series over the 55 series makes a difference as that is the only thing that I can see that would prevent rubbing.
So you are saying that +35mm w/50 series won't rub. But if you go 55 series with +41 you will since that is what I have.
Old Jan 26, 2009 | 06:36 PM
  #39
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
it rubs but is not a big deal, is like Ray says. only rub the fender liners... and i dont have my fenders roll. and if it rubs is when you take bump or somthing, but i been taking pretty big bumps and still no rub lol...
Old Jan 26, 2009 | 06:44 PM
  #40
FitFlowjoe's Avatar
I'm running 15" Black Rpf1's w/ 41 offset with 195/55 Direzza Z1 Star Specs.. and I rub alittle in the front, but once the fender clips fell off, no more rubbing.. And I do Auto-X.
I'm using Tanabe's GF-210 but soon to go Skunk2 Coilovers and camber bolts. And I want to use 205/50 in the front.. well see what happens there
