how to open fuse box?
Old 01-22-2009, 03:20 AM
panda1314's Avatar
yes as stupid as it sounds im having difficulty opening the fuse box....are there any taps im suppose to pull or turn before i pull the cover off? the owner's manual just says "pull towards you when removing the fuse box cover". When i pull on it, it seems like its being at the top held by 3 tabs. Left/Centre/Right. The L/C came out fine but the right is fairly tight. I didn't want to pull any harder and break something.
Old 01-22-2009, 03:21 AM
koolkevin1107's Avatar
i'm assuming the fuse box under the hood.... yes it has 3 tabs. They all come off the same way, u have to pull the tab opposite from the lid and lift up the cover. It's easy.
Old 01-22-2009, 03:23 AM
panda1314's Avatar
my apology i should've specified which fuse box, i was refering to the one inside under the steering wheel
Old 01-22-2009, 08:22 AM
Virtual's Avatar
Just pull the handle (just under 3 switch covers) and the panel swings downward. It's held in place by a few clips.
Old 01-22-2009, 10:31 AM
reako's Avatar
Yeah I remember not wanting to pull that hard at first either...but the clips are designed to be removed like that so no worries...good luck!
Old 02-18-2009, 11:52 PM
Superfitfreak972's Avatar
Do you pull it down or toward you??
Old 02-19-2009, 12:16 AM
Tork's Avatar
Location: Winthrop Harbor Illinois/ Presque Isle Wisconsin
both really, the top of it opens and pivots down. Crouch down just outside the drivers door and give it a tug.
proaspen
08-14-2012 09:00 PM
Neil-in-Arizona
07-25-2009 02:01 AM
kyo2529
10-02-2007 01:37 AM
FitLIKEaGlove
02-17-2007 11:52 AM
sLiVeRwOrM
05-13-2006 11:02 AM
Quick Reply: how to open fuse box?
