My first post on FitFreak
Wheel: Rota Circuit 10
Offset: +45
Color: White (repainted)
Tire: Bridgestone Potenza S-02 Pole Position/Toyo Proxes 4
Size: 205/45R16 for both tires
Lowered?: No
If Yes, What Setup?:
Front Rubbing: No
Rear Rubbing: No
Comments: I use Work RS lugnuts, anodized red, hex size 21mm. I also use a set of machined aluminum hub-centric rings to ensure proper loading on the center spigot, not on the wheel studs (check the last photo). The old S-02PPs had rim guards, the newer Proxes 4s don't but are much quieter and longer-lasting. I have zero rubbing on the bodywork. We'll see how well they fare once my Aibo gets coilovers.
