View Single Post
  #34 (permalink)
Old 02-02-2009, 03:42 AM
02bugeyeworks 02bugeyeworks is offline
02bugeyeworks is an unknown quantity at this point
Quote:
Originally Posted by solbrothers View Post
if you guys are worried about the tire being too wide for the rim, look at any offroad vehicle. especially rock crawlers. they run tires 5 inches wider than the rim in most cases.
also, my brother had 295/50/15 tires on his crown vic. 15x7 rims
OH MAH JESUS. 295s on a 7 inch wheel?! haha whatever works. That is right about the off-road vehicles, but the concerns are not all unfounded. For on-road applications the sidewall strength and how it is mounted on the wheel is much more important as it will tend to give or roll under high g force turns if mounted on to small of a wheel. The off-road tires will usually slip on whatever surface they are traveling over before this happens. That said, there is still room to play around as I stated in my earlier post.
__________________
2002 Subaru Impreza WRX Sport Wagon (Stage 2)
2009 Honda Fit
