View Single Post
  #229 (permalink)
Old 02-05-2009, 05:13 PM
YeeFit's Avatar
YeeFit YeeFit is offline
YeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to live
1WayFit - try RCTS here in Calgary. They are a certified HKS tuner shop.
That is the big knock on the HKS kit tho that i've warned many about.. Hard to locate a certified tuner and low power since its CARB legal. You need to get on par with the T1R kit so that you have bigger injectors, test pipe, and then up the boost. Emanage tuners are everywhere... you could go straight to AJ-R in Richmond for that.
