View Single Post
  #23 (permalink)
Old 03-08-2009, 04:13 PM
sl0wp0k3 sl0wp0k3 is offline
sl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to livesl0wp0k3 relies on Rep Points to live
i got a question about ground control...can you pick any 2.5" ID spring?
on the GC site, they have G.C. spec springs, and they also have other springs.
also...have your springs ever been too short, as in does the shock extend further than the spring? cause if you get stiffer springs and want the car to sit lower, and you have the same travel in the shock, potentially, the shock can extend further than the spring will. do you need to use helper/assist springs in this case, or is there another alternative? can you adjust shock travel on konis?
on the dg's autox secrets stuff, it says that konis can be very unmatched when bought...is there any way to avoid this?
__________________
guess what?!? my Fit is USDM!! and STOCK!
