RC Injectors 310cc
Old Apr 14, 2009 | 04:04 PM
gd3kamiwanaB's Avatar
Luvs Dah b00st!
RC Injectors 310cc
ok well i had to step up and get 550cc injectors so i wont need these 310cc's there still perfect, ill also include the special clips to run them in your fit as well as the mounting hardware to use the stock fuel rail, ill ask 200, pretty firm because the injectors were originally 400 and then another 90 dollars for the clip, your not gona find a better deal then that
Old Apr 14, 2009 | 08:13 PM
dewthedew's Avatar
$75 ?
How much do these go for?
Old Apr 14, 2009 | 08:38 PM
Luvs Dah b00st!
new there a lil over 400 so id maybe willing to go half. but hey, money talks
Old Apr 15, 2009 | 10:15 AM
NIGHTHAWKSI's Avatar
whats the difference between rc310cc and OEM honda 310cc?
Old Apr 15, 2009 | 10:44 AM
Luvs Dah b00st!
bigger magnet, bigger core, stronger seat and valve, all four flow tested and grouped within 1cc of each other, with factory injectors u get VERY inconsistent flow rates. and if ur gona try to make any kind of reliable power ud be a fool to use a still factory injector as a performance up grade, the quality and the consistence is just not there.
Old Apr 15, 2009 | 09:32 PM
Luvs Dah b00st!
bump bump comon $200 bux takes em!!!!!!
Old Apr 16, 2009 | 10:50 PM
Luvs Dah b00st!
bump, new offer, read first post!!!!!!!
Old Apr 18, 2009 | 03:02 PM
Luvs Dah b00st!
bump!!!!!!!!!!!!
Old Apr 19, 2009 | 04:25 AM
Luvs Dah b00st!
full injector set up for the fit 310cc with mounting kit and honda clips. 200 bucks BUMP!!!
Old Apr 20, 2009 | 11:00 AM
Luvs Dah b00st!
bump......
Old Apr 21, 2009 | 01:35 AM
Luvs Dah b00st!
bump.......
Old Apr 21, 2009 | 05:15 PM
CamFit's Avatar
Free bump, also a question... y 550 howmuch boost are you running into your fit?...
are the injectors from the T1R kit? if so what other upgrades did you preform to run all that boost that you would need 550's?
thanks in advance
Old Apr 21, 2009 | 07:27 PM
Luvs Dah b00st!
https://www.fitfreak.net/forums/fit-...o-booooom.html
https://www.fitfreak.net/forums/fit-...ld-thread.html
these are the same injectors that are in the t1r kit
il running 20 lbs as of now soon going to 25 with new turbo
Old Apr 22, 2009 | 07:29 PM
CamFit's Avatar
sweet stuff, read both post's and all i have to say is........ what can I say....... modding is 1 thing... modding and sharing your trials and tribluations with like minded people who share common lifestyle choices.. ie Fit... is sompthing else.
knolage is power (no pun intended) thanks for sharing... also free bump=)
Old Apr 23, 2009 | 11:42 PM
wirednj's Avatar
Did you sell the injectors yet? Do you know how much I could boost on a stock engine with this injectors without blowing the engine?
Old Apr 24, 2009 | 02:03 AM
Luvs Dah b00st!
with these injectors i ran 10lbs daily with Air/Fuel in the low 11's making around 165 WHP
and yes they are still up for grabs 200 and free shipping.
PM me. If u want them, there all yours. Includes the clips and all the mounting hard ware u need to drop them in to a 07-08 FIT
Old Apr 24, 2009 | 10:56 AM
wirednj's Avatar
I have the HKS bolt on kit using factory injectors and running with 5.2 psi and not tuned yet . Would the stock engine handle that amount of boost (10psi)?
Old Apr 24, 2009 | 01:19 PM
Luvs Dah b00st!
mine did for 15 k miles but i wouldent sugest it. but ur fine with 8 psi, in which case ull slill need bigger injectors
Old Apr 26, 2009 | 05:34 PM
Luvs Dah b00st!
bump.......
Old Apr 27, 2009 | 12:16 PM
Luvs Dah b00st!
bump1111111111111111111111111111
