Thread: Tire Pressures?
View Single Post
  #10 (permalink)
Old 04-20-2009, 10:43 PM
Sugarphreak's Avatar
Sugarphreak Sugarphreak is offline
Sugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to liveSugarphreak relies on Rep Points to live
Rule of thumb is usually add 10 psi for the track; then make adjustments on each run as necessary. The tires will heat up significantly after your first run so you will have to bleed them back.
If you are talking about driving on the street, I usually run around 35psi gives a nice all around responsiveness depending on what kind of tire you use.
__________________
For a jolt of pure awesome... just click the sugarphreak button!
