Quote:
Originally Posted by Sugarphreak
Some good idea's, I might have to look into colder plugs and see what I can make happen with a mid grade or premium fuel.
So you are thinking that 13.7 is the ideal WOT A/Fr then?
I am not sure about the timing, originally AJR had been subtracting just a couple of points between 2500 & 4500rpm's. But since that tune I have removed a lot of fuel on the new map, all my boxes are minus @ WOT now. It almost seems like I should be advancing the timing, but I am a bit scared to do that.
I still haven't seen anybody come out with cams or heads for the L15 yet, I would love to see some more aggressive Naturally Aspirated options come out.
Catcams has upgraded cams, valve springs, and retainers for the Fit.
CATCAMS Introduction page: the pearly gates to engine power!
EDIT: WTF is AJR removing timing from your car on an N/A setup. That makes no sense unless there was something wrong to begin with.
