shout me all your contact info in a pm Nick and I will give that to him so that hopefully he gets back to you.
He should be fully moved into his new shop so it should be easier to reach him. I will do my best to assist you in any way I can but things are getting crazy busy for me and my first track time is on the 20th and here is what I need to finish:
install both inner tie rod ends
set ride height correctly for all 4 corners
get an alignment done
freshen up the rear brakes probably with new pads and drums
change out brake fluid for Wilwood 570 high temp race fluid
install airbag block off plate on passenger side
finish installing full decal package
Disconnect airbag equipment on steering wheel and remove some components back there
Possibly dry ice floorboards to remove sound deadening
clean inside and out and engine bay
edit forgot also needs an oil change, plugs changed and a coolant flush :P
Should be easy to do normally but my daughter's birthday is this weekend and I have other projects booked for both weekends after that :P
__________________
2008 VBP Fit LX M/T
3m clearbra
Keyless entry
Sport Spoiler
Zeta dead pedal
JDM centre console w/ armrest
