Magnetic Drain Plugs - Additional Insurance for Your Engine
Old May 5, 2009 | 01:20 PM
Benggolf's Avatar
Thumbs up Magnetic Drain Plugs - Additional Insurance for Your Engine
Magnetic Drain Plugs were pioneered by Lisle Corporation in the 1930's. Lisle MAGNETIC PLUGS are similar to standard pipe or straight thread drain plugs with one important difference – a permanent magnet is fastened to the plug body. This magnet attracts and holds abrasive, ferrous metal particles preventing their circulation through the lubrication or hydraulic system.
These abrasive, ferrous metal particles appear in lubricating or hydraulic systems as a result of the following conditions:
- The constant flaking effect of normal wear of moving parts.
- Particles not removed by flushing operations after boring or machining.
- Chipping due to sub-surface casting flaws.
- Minute component breakdown caused by stress usage.
Usually a combination of factors accounts for the presence of these particles that cause excessive wear to vital components unless they are removed. By holding these particles, Lisle MAGNETIC DRAIN PLUGS prevent excessive wear to the system's components.
World War II proved the worth of MAGNETIC DRAIN PLUGS. Lisle MAGNETIC PLUGS helped protect American Jeeps, tanks, trucks, aircraft and other wartime equipment in rugged operating conditions around the globe.
Lisle manufactures MAGNETIC PLUGS in a wide variety and range of sizes, magnet types, and body styles.
Standard Lisle MAGNETIC PLUGS (many of them stock items) are shown in this catalog. In addition to these standard parts, Lisle engineers will design MAGNETIC ASSEMBLIES to meet specific applications that may not be covered by a standard part.
Today, Lisle MAGNETIC PLUGS are used by numerous manufacturers of gear boxes, transmissions, engines, and hydraulic systems for the automotive, aircraft, agricultural and machinery industries. Typical applications include:
- Outboard Engines
- Earthmoving Equipment
- Combines
- Balers
- Crawler Tractors
- Lift Trucks
- Mining Equipment
- Military Vehicles
- Turbine Engines
- Truck Axles
- Heavy-Duty Transmissions
- Diesel Engines
- Trans-Axles
- Motor Cycle Transmissions and Engines
- Lawnmower - Tiller - Garden Tractor Engines
- Air Conditioning and Refrigeration Compressors
- Hydraulic Systems
- Oil Well Equipment
- Speed Reducers and Gear Boxes
- Pumps
- Hoists and Cranes
- Printing Presses
- Drilling Equipment
- Farm Tractors
- Recreational Vehicles - Snowmobiles - All Terrain Vehicles.
Old May 5, 2009 | 01:26 PM
Benggolf's Avatar
Photo of a Magnetic Drain Plug
Here's a photo of the magnetic drain plug I got for our GE8.
Part numbers ending with "M" have a Ceramic magnet
Part numbers ending with "SM" have a Neodymium magnet
You can order from C.G. Enterprices
Honda magnetic oil drain plugs
Part Number - #1085SM (Magnetic Drain Plug)
#2403 (Gasket)
Old May 5, 2009 | 01:30 PM
Guinness's Avatar
Where do I get that for the GDs??
Thanks for bringing this up Beng~ I guess its time to visit AJR
Old May 5, 2009 | 01:37 PM
Benggolf's Avatar
You can order on line. See Post #2. Why are you still home?
Dim Sum at 10:45AM remember?
Old May 5, 2009 | 07:17 PM
Guinness's Avatar
LOL, Thanks for the plug Beng~ Cant believe I got a Bday gift from you before my Girlfriend~ LOL
Got the O-Ring for 25cents~
Old May 5, 2009 | 07:28 PM
Benggolf's Avatar
You are most welcome!
Old May 5, 2009 | 07:30 PM
Benggolf's Avatar
Application: Part Numbers
BTW, please be advised that Part #1085SM (Magnetic Drain Plug) and
#2403 (Gasket) are applicable for all Honda passenger cars from 1992-2009.
Kevin Evans
Sep 26, 2020 02:05 PM
Bryanfit
19
Mar 17, 2017 02:03 PM
doctor J
Aug 26, 2016 03:33 AM
honda007
May 31, 2016 08:51 PM
wackyflik
Oct 4, 2014 09:11 AM
