The base data look something like this for a totally stock Fit on the same machine: This will be my baseline data to compare against as I plan to use the same machine in close to the same temps.
Dynamometer; Mustang Dyno
NOTE: This machine typically reads a bit lower than a dynoJet, much lower than a dynopack.
Approx Elevation: 3000ft above sea level
This will play a factor on the max power output, keep that in mind
Temp: 9 Degrees ambient
Max HP: 86.7whp @ 5800RPM
Max Torque: 83.9whp @ 4900RPM
I did do a dyno before; you can do a search for the thread; however I believe the results were comprimised with some unforeseen factors coming into play.
__________________
For a jolt of pure awesome... just click the sugarphreak button!
