Drag racing setup question
Old May 10, 2009 | 10:55 AM
Midnightfit's Avatar
want should my setup be for the 1320 or 1/4 i am building my car to run a supercharger or turbo to hopfully hit high 13. with d/r or slicks
Old May 12, 2009 | 03:33 PM
yah, ive never setup a car for serious drag racing other than my RC car. lol
understeer is your friend when you want to go fast just straight.
so, wat i'd do is:
1) get oversized front swaybar.
2) use maybe 250lbs/in front springs and adjustable dampers in pretty stiff but not too stiff setting. you dont want wheel hop.
3) use ~400lbs/in rear springs and stiff setting. no rear swaybar cause you dont want the rear to rotate while you're doing. keep the rear ride height high, even use a wheelie bar to keep the
front down on the tarmac.
i donno... i think you can do it. im sure other will now
chime in.
Old May 13, 2009 | 08:22 AM
MarkyMark's Avatar
Civics have been drag racing for years. I'd research the set ups of those to use as a starting point.
Previc93
16
Nov 28, 2013 10:47 PM
hayden
18
Apr 30, 2012 12:12 PM
MSILVEST04
Jul 14, 2011 12:36 PM
HONDAMATIC
Oct 26, 2007 09:27 PM
Vale 46
May 9, 2005 01:49 PM
