I had a customer in Guam and his Fit is driect bolt on, so if your fit is the same as the one selling in Guam, then should be direct bolt on.
By the way, our spoilers' openings are exactly the same as the real Spoon from Japan, so maybe you can check if the real Spoon can directly bolt on your Fit.
Thanks
