View Single Post
  #71 (permalink)
Old 05-26-2009, 04:18 PM
TheImmortal TheImmortal is offline
TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal
Quote:
Originally Posted by Jodele View Post
Specialty Products front wheel camber bolts work as advertised. They will adjust 1.75-degrees to either side for a total of 3.5-degree adjustment.
http://www.spcalignment.com/PROD_DIR/SPC_PROD_SEARCH_DYN.cfm?cmd=Cam&cmd2=81260&cmd3=
very good product.
I’ve got my front wheels adjusted to 0.1-degree negative camber (the tops of the wheels tilt outwards). This did two things for me…it lessened the slight over-steer in long hard corners and it wares the tires on the outside while the rears, set at 0.5-degree positive camber ware the tires on the inside.
u got the whole negative/positive thing backwards!!!
....makes me (and hopefully others) go hmmmmmmm
