View Single Post
  #15 (permalink)
Old 06-03-2009, 03:59 AM
Texas Coyote Texas Coyote is online now
Texas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to live
I did it and love it.... I deviated slightly from from your plans and bought a heavier screen door spring probably 0,52" or a little bigger,and smaller hooks.... I had a rubber padded wiring clamp I used on the pedal rod with one of the hooks through the two holes after clamping the ends together.... I had to cut the spring an inch or two longer than 5 1/2" or it would have been too stiff I covered the one that went in the hole under the dash with clear plastic tubing.... I have to admit that I wish I'd of had a larger hook for under the dash, I couldn't fit under there well enough to see the hole and I spent more time hooking it than anything else..... I am grateful to you for sharing this.
