need fenders rolled socal
Old Jun 3, 2009 | 11:14 PM
ennjoi's Avatar
anyone know of a place that rolls fenders.
Update: i rolled the back fenders, but wanst the problem there is a lil lip with a screw that holds the corners of the back bumper on, its tearing up my side wall, what to do what to do?
Old Jun 4, 2009 | 12:26 AM
Fitting's Avatar
He might find a roller on ebay but not likely a place.
Post up in the Socal section as some locals might know.
Old Jun 4, 2009 | 02:38 AM
ghettoboy247's Avatar
aww snapz, hit me up, i got jes the solution
Old Jun 4, 2009 | 03:22 AM
ennjoi's Avatar
thanx fellas. just ended up doing the ol baseball bat method
Old Jun 4, 2009 | 10:43 PM
ennjoi's Avatar
help me out read update on 1st post
Old Jun 5, 2009 | 12:17 AM
tanukifit's Avatar
use you pointing and middle finger and lift that tab up and it should bend fairly easy
Old Jun 5, 2009 | 12:25 AM
nxtfit_08's Avatar
you got to cut it out and zip tie it ask ray he did mine i had the same problem
Old Jun 5, 2009 | 01:34 AM
ennjoi's Avatar
im gonna try to bend it if not, ill cut it and zip tie it. thanks alot
Old Jun 5, 2009 | 01:48 AM
JDMchris.com's Avatar
I run THIS
u can shave it down.
Old Jun 5, 2009 | 03:02 AM
ennjoi's Avatar
yeah ill probably try that first. Any one running a 7.5 wide wheel?
Old Jun 5, 2009 | 03:46 AM
tanukifit's Avatar
bend it, don't shave or cut anything!!
Sorry I don't mean to offend anyone but, this is the safest and cleanest way
Old Jun 5, 2009 | 09:03 PM
ennjoi's Avatar
it wont bend.. its not metal it feels like plastic so eaither its cutting it or shaving
Old Jun 5, 2009 | 09:19 PM
tanukifit's Avatar
It's the fender on top that's clipped to the bumper that's plastic. It will bend, find a friend with the Heman grip to do it or try using gloves.
Old Jun 6, 2009 | 12:22 AM
ennjoi's Avatar
ok so i bent that little metal piece you were talking about now how do i get the corner of the bumper screwed on?
Old Jun 6, 2009 | 04:03 AM
tanukifit's Avatar
Sorry I had to go dinner.
1. I bent mine while it was still connected. I think with a little softening with a heat gun you should be able to attach it.
2. Or you can bend it back down attach it then bend it up again.
I think 2 would be easier.
Old Jun 8, 2009 | 11:52 AM
Fit4Trav's Avatar
Im running a 8 w/ +20 offset in the rear. and before I was running a 7 +13 in the rear.
I let the plastic kinda naturally shave off from rubbing. My bumper holds on tight and clips/screws in still. No zipties
Old Jun 10, 2009 | 02:11 AM
ennjoi's Avatar
yah i wouldnt have mind it rubbing away but my side wall is taking a beating its gashing my side wall.. i believe i found the problem.. i have my 250lb brother bounce on the back while i was looking at the back fender. the lip on the back bumper was hitting the tire so i shaved alot off, took it around the block went in dips and didnt hear anything i hope that was it. Thanks for all the help and tips
score04w
Mar 27, 2011 08:27 PM
ThEvil0nE
Jan 8, 2011 02:56 AM
CAFit
Jan 21, 2010 11:11 AM
cdezspykez
Jan 22, 2009 01:29 AM
ezekielwhore
Apr 20, 2006 10:17 PM
