"CHECK GAS CAP"... what?
Old 06-05-2009, 09:32 PM
Sugarphreak's Avatar
Push My Button
Ok, where the maintenance minder usually displays the mileage & oil life something new started up today.
Upon startup it is totally blank and it starts flashing 3 words, one at a time
"CHECK"..... "GAS".... "CAP".....
ok, fair enough... I was down to about 1/8 of a tank of fuel so I shut it down and hopped out to check the gas cap. It was on tight
So I grabbed a tank of fuel on the way home... yet the message has been persisting everytime I start up.
Do I have a pressure leak or something? Anybody else experiencing this?
Old 06-05-2009, 09:40 PM
keepitpg's Avatar
i love college
thats weird..
Old 06-05-2009, 10:32 PM
koolkevin1107's Avatar
I've heard that the message will go away after about 1-3 full tanks of gas. If it doesn't leave by then, ECU reset (disconnect battery for 5 minutes) and it will clear it.
Old 06-05-2009, 10:40 PM
Spooling's Avatar
you are not alone sugerphreak
I get that "Check Gas Cap" message once in a while. It always clears by itself after a day or two. It has nothing to do with the gas cap. I believe it has to do with the fuel trim/map and injectors.
I would love to get some more info regarding this error
Old 06-06-2009, 12:31 AM
Push My Button
Hopefully that is all it is, I am hoping there isn't a leak when it pressurizes the system causing it.
I will have to bust out my LM2 and clear the code when I have a chance
Old 06-06-2009, 11:26 AM
BC-Fit09's Avatar
sugarphreak...check out the old threads at the very bottom of this page...note the first one:
https://www.fitfreak.net/forums/1st-...-fuel-cap.html
"Check Fuel Cap"
Hey, I drive an 08 USDM AT Fit. Today I drove the car to school (arrived about 7:00 am) and had no "check fuel cap" message. After school (around 11:30) the message was there. Filled gas last Wednesday (week ago) and already checked to see the fuel cap. (Clicked it like 4 or 5 times).
Any help?
Thanks for your time
Umar
EDIT:
So, within minutes of posting, I figured out how to fix it. Not to sure however what caused it. For those interested:
1) Turn off car
2) Remove gas cap
3) Start up car
4) Put gas cap on
5) Done"
Old 06-06-2009, 12:44 PM
Push My Button
Thanks, I totally missed that thread!
Old 06-06-2009, 10:04 PM
BC-Fit09's Avatar
I'm curious...did it work??
Old 06-06-2009, 11:50 PM
wdb's Avatar
wdb
wdb is offline
I had that message come up once. I forget the exact sequence of events but they involved removing and replacing the gas cap and restarting the car, and the light did clear. And no my gas cap was not loose.
Old 06-07-2009, 04:44 AM
doctordoom's Avatar
Supervillain
are you using the OEM gas cap or an aftermarket locking one? just in case you didn't know, it won't necessarily clear the "check gas cap" message immediately after you fully tighten the gas cap. i had it happen too, after using a stant locking cap for a little over 2 years. the cap was on tight, but after a day i switched back to my stock cap and the msg cleared a day later or so. then i replaced it with another locking cap and it's been all good so far. just don't worry if it doesn't clear right away, i think it just depends on when your car runs a fuel system check at startup again.
thc888
04-02-2012 09:38 AM
Goodguy-Fly
06-15-2009 12:32 AM
pastafarian
06-11-2008 10:34 PM
seizure
01-27-2008 10:26 AM
fitjunkie
05-31-2006 01:40 PM
Quick Reply: "CHECK GAS CAP"... what?
