so if u want to boost to 10 psi will the 310's that come with the t1r kit work?... or will i need 370's min or 450s for some leayway incase i deside to build the motor later.... also will the fuel pump need to be upgraded?
Im hope that 310 that come with the t1r kit will be sufficent to run 10 psi.... but better to know now before i tune than try to tune @10psi and max out the injecors..... or the fuel pump...
thanks in advance
Cam
__________________
"volks just look so much better with brembo"
