JDM/EDM headlight adjustable switch/unit - USDM GD Fit
Old Jun 9, 2009 | 06:34 PM
fitdeaf's Avatar
FitFreakers-
Since I have all, if not, most of the necessary parts and wiring diagram for headlight adjustable unit (it would be located next to the power-folding mirror switch inside my car – same location for JDM coin tray, in case you may be wondering) as seen in JDM/EDM model, a set of adjustable headlights is required to complete the installation.
My question is - could USDM headlights be fitted with adjustable unit? If not, is it possible for the imported (JDM/EDM) adjustable headlights to fit (no puns intended) with USDM front end, perhaps, with the use of spacer (for lack of a better term) or related fitment?
Your advice/input would be greatly appreciated.
Damien
Old Jun 10, 2009 | 03:54 PM
gimme's Avatar
Master FitFreaker
I dont think the headlights would work with our front end. the over all length is different as well as the angles of them. You could possibly space them out, but the angles would look bad I would think.
Old Jun 10, 2009 | 06:26 PM
gd3vbp's Avatar
If you have the time to do it, and the money for a set of edm headlights you could swap over all the moving components then wire it up to make it work.
Old Jun 11, 2009 | 06:40 PM
fitdeaf's Avatar
gimme-
I do completely understand that fitment may be out of question, even though the larger USDM headlights may have similar appearance as the smaller EDM headlights – unlike the JDM counterparts. I thought the larger bulb component (one with high-beam/low-beam, not amber, if I am making sense) could be easily swapped with the adjustable unit, no?
Damien
xxryu139xx
Dec 1, 2012 12:23 PM
mikow
16
Sep 30, 2010 05:06 AM
fitdeaf
European Fit Forums & Clubs
Jun 20, 2009 06:20 AM
benmunger
Jan 21, 2009 09:44 PM
jdjohnson9
Feb 10, 2008 12:23 PM
