View Single Post
  #19 (permalink)
Old 06-14-2009, 01:53 PM
quick92ciFit's Avatar
quick92ciFit quick92ciFit is offline
quick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to livequick92ciFit relies on Rep Points to live
Quote:
Originally Posted by Uncle Gary View Post
So, if I change the oil early, how do I deal with the other recommended services that won't show up until the "15%" point is reached on the meter. If I keep resetting the meter at 5,000 miles or 50% (or whenever) when I change the oil, I might miss other services, right? There's no mileage or time figure listed for tire rotation, air cleaner replacement, etc. They are also run off the meter.
Those service indicators more than likely run off the mileage on your car or sensors that trigger the CPU to turn them on. Resetting the oil life meter should not effect those service indicators from coming on.
__________________
2009 Fit Sport Taffeta White / AT
Done: K&N Filter, UR Rear Sway Bar, Ambient Lights & Sport Grille.
To do list: waiting for Tanabe to release the Touring Medalion Exhaust & someone to release some aftermarket shocks & struts so I can drop her on some DF210's.
