Quote:
Originally Posted by mahout
Ideal is not the same as MINIMUM. If you use a wheel with offset LESS than 42 mm you have a 90% chance of interference unless you use a way too small width tire.
And yes, 45 mm is ideal because it gives some room to lower if not too much. At 42 mm if you lower you get interference..
Just a follow up on my posts & questions about fitment for 15x7 +38...
Taking a risk, I went with my original choice of wheel & bought XXR 501s in black; they are 15x7 +38 offset. I had them mounted on my stock Dunlops (15x6.5) and there are no rubbing issues so far. I am not lowered, but was told I could probably still do a moderate drop and be okay.
Thanks for everyones input.
Heres a pic of them on:
