View Single Post
  #2 (permalink)
Old 06-18-2009, 11:10 AM
Texas Coyote Texas Coyote is online now
Texas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to liveTexas Coyote relies on Rep Points to live
I have driven turbo cars with low compression ratios and found them to suffer low RPM lag.... Wouldn't it be better to install a self tuning device like the AEM A/F/I to set the mixture and timing than installing a thicker head gasket that will lower the compression ratio?.... I can see where a thicker gasket would be beneficial if you were pumping some really big boost and planning on keeping the revs up all of the time in a purpose built racing engine that wouldn't see much street use..... If that is the case you may have to make (or have one made) of solid copper, using a stock gasket as a template.
