Yes, I used 3 SPC kits; I split one of the kits in half to get an extra ¾ degrees adjustment on each axle stub. And it’s actually very good because the plastic is sandwiched between two flat pieces of metal (axle stub and rear axle beam). But I needed to use longer bolts on the wheel stub. I used 3 plates on each axle.
