Quote:
Originally Posted by racetek82
Considering that the rear suspension on a FIT is a straight axle, there would be NO change in camber. The reason you have a change in camber on your S2K is because you have control arms that change geometry when you raise or lower your vehicle. The FIT does not use this same rear suspension design as most other Hondas. Take a look at the Scion guys, they use camber shims to create negative camber, and they use the same straight axle. Lowering an xB will not change rear camber either.
atleast you understand why i say there is no adjustment need or can really be done.
