Quote:
Originally Posted by GTornado
Well, I've done some research here and Honda is only offering the L13A engine for the new Fit. So, there seems to be no other way than importing an engine. I am not sure, but the GE L15A does have some differences to the GD engine, doesn't it?
I already mentioned the slightly different intake design, but this is shared among all GEs. I know the intake manifold itself is also shaped a little differently.
The main difference is the i-VTEC head on the GE L13A and L15A. The GD L15A's VTEC is basically a valve-idling mechanism...below 3500 RPM the engine uses only one intake valve per cylinder. The i-VTEC head adjusts timing and lift across the whole range.
2009 Honda Fit Sport - Honda Tuning Magazine
Other differences would probably involve the wiring as Jazz it up! has stated.
Temple of VTEC Asia has detailed technical write-ups on the GE L-series engines if you're curious.
Honda L-Series SOHC i-VTEC Engines for the new GD Honda Fit/Jazz
More power in stock form is always good
