View Single Post
  #10 (permalink)
Old 07-01-2009, 03:32 PM
IBJanky's Avatar
IBJanky IBJanky is offline
IBJanky relies on Rep Points to liveIBJanky relies on Rep Points to liveIBJanky relies on Rep Points to liveIBJanky relies on Rep Points to liveIBJanky relies on Rep Points to liveIBJanky relies on Rep Points to liveIBJanky relies on Rep Points to liveIBJanky relies on Rep Points to liveIBJanky relies on Rep Points to liveIBJanky relies on Rep Points to liveIBJanky relies on Rep Points to live
Quote:
Originally Posted by Vanct View Post
Get the Fit, it's definitely the best bang for the buck. The fuel economy alone is worth it over the xB if you plan on keeping it for a long time (and you will be able to because it's a Honda). I wouldn't go for the Navi though, you will probably save more buying aftermarket.
The Fit also holds it's resale value very well.
Yeah, Honda vehicles usually hold their value better than most other manufacturers.
As far as the Navi, I want to get it because I want the Vehicle Stability Assist feature. Also, I like the fact that everything is integrated with the Navi unit, steering wheel controls, iPod, etc.
I do have a question about the Navi unit... is it a DVD based unit (will I need the map disc inside the unit all the time), or is it hard drive based (no map disc required)?
myke
