View Single Post
  #15 (permalink)
Old 07-06-2009, 08:05 PM
secondspassed's Avatar
secondspassed secondspassed is online now
secondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to livesecondspassed relies on Rep Points to live
I just went out and looked at my fogs and the one that's broken has some condensation trapped inside the housing from when I washed it. Some water had gotten inside of the housing through the hole in the glass. I thought I had gotten it all dry with a blow dryer but apparently there's still water in there.
Should I leave it alone and it will eventually dry up, somehow? I can't imagine since it's sealed pretty tight how the water molecules will ever make their way out. I was thinking I may have to poke a tiny hole in the protective film with a needle, over the big hole in the glass but this would potentially allow moisture back in later.
Anyone have any thoughts?
