View Single Post
  #10 (permalink)
Old 07-06-2009, 08:45 PM
Fluffywings Fluffywings is offline
Fluffywings is an unknown quantity at this point
Quote:
Originally Posted by MetalHead88 View Post
its the same install for components...
How so?
Correct me if I am wrong. I have the LX so I would have to run the wiring for my components as well as mount the tweeters. I also found out in the forum that the tweeters that come with Infinity Components do not mount nicely in the stock location.
2nd if you put subs in the doors they arent going to sound tight at all, they are just going to sound like a fart...quality will be absolutely terrible. BAD idea.
A free air sub vs sealed only differs in its efficiency. The air in a box acts like a spring. When the sub moves outward, the air is under tension. This creates a low pressure vacuum that pulls the sub back to equilibrium. The sub then goes back to that equilibrium point but moves past it into the box. This causes compression of the air. The air pushes the sub back out. All this does is make the sub do its work more efficiently as the air helps the sub move in and out versus with free air that does not happen. Free air rolls off faster then a sealed box design causing less bass at low frequencies however it is still a smooth curve just like a sealed box. As a result a sealed box running the sub at say 75Wrms should be equivalent to the same sub in free air running 150Wrms (or something very close).
my friend has alpine type r coaxle speakers that are amped. they sound good at low volumes, but they really cant handle high volumes in any way watsoever. go with comps! they will thump nicely with the bass.
Comps are still midbass resulting in peak bass closer to 200Hz. With a dedicated sub, frequencies down to 50Hz or lower should be achievable.
if you are as lazy as you claim to be, just swap out the headunit. alls i have is the head unit, and the subs in the trunk. i cant imagine enjoying music at a higher volume then its currently at. with stock speakers, its clear as hell.
I do not want to swap out the head unit.
Thanks for your 2 cents. I am thinking about the components install now. Hmm, decisions, decisions.
