the oil feed will be 180' away from the return (the large hole in the bottom with a flat surface and two threaded holes where a flange bolts to.) then most td05's have coolant passages that run cross flow (the other two threaded openings. flow orientation doesn't matter)
who's manifold are you going to be using? what size is the turbine housing? 6 cm? it will be a laggy turbo but should pull nice up top. as for where to tap off the coolant. I would just tap off the throttlebody or bypass it entirely and run the two hoses to the turbo. also who's tuning it? talk to hondoctor's and ask when jeremy (servion) is coming back to tune and get on the waiting list. highly reccomend him!!!
__________________
2008 SSM Tanabe GF210 springs, Tanabe front strut bar, progress rear sway bar, Drag dr21's gunmetal, S2 short shifter & knob, Mishimoto intake, 8k hids, 4.3k fog's.
