View Single Post
  #7 (permalink)
Old 07-10-2009, 10:12 PM
nekret nekret is offline
nekret relies on Rep Points to livenekret relies on Rep Points to livenekret relies on Rep Points to livenekret relies on Rep Points to livenekret relies on Rep Points to livenekret relies on Rep Points to livenekret relies on Rep Points to livenekret relies on Rep Points to livenekret relies on Rep Points to livenekret relies on Rep Points to livenekret relies on Rep Points to live
Alright I'll take a shot at this...
1st: I'm guessing this mod is for a vtec light considering I don't think I've seen anyone else here use a relay to drive a single led.
2. LED's are polarity sensitive:
So with this information, take the cathode (negative side), solder a wire to it, and put a ring on the wire and bolt to a ground (usually a bolt that taps into the body somewhere). take the anode (positive side) solder a wire to it and connect the wire to the power source you want to use (guessing vtec wire).
