I decided to join the band wagon on this install so here is a pic.
I had some fitment issues when using the two 90 degree elbows where the filter was hitting the battery. To remedy this I cut about a half inch of the first 90 bend where it connects to the throttle body. Then I did away with the second 90 degree bend and went with a 45 degree bend instead. Problem solved. Sounds pretty good and a good hold me over untill I get the T1R around Christmas.
