View Single Post
  #150 (permalink)
Old 07-21-2009, 08:15 PM
TheImmortal TheImmortal is offline
TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal TheImmortal
Quote:
Originally Posted by kenchan View Post
also note that these are progressive rate springs...meaning, they have
initial and full compression rates and many variable rates in between.
those numbers are to be used only as a guide... there is no indication
whether those are initial or full or just averages.
if you see a rate like 500lbs, you know they are very stiff.
if you see 2 different rates from the same manufactuer then
you can tell which are stiffer as they probably (assuming)
used the same measuring method(s).
2 different rates from 2 different manufacturers.... you can only
guess.
mine r 560in/lbs rear , 448in/lbs front....linear
