GE Light tuning
Old Jul 30, 2009 | 07:46 PM
fluid's Avatar
GE Light tuning
GE with Automatic gear
1. Reflashing ECU with Piasini when STD
2. Air Filter from Simota
3. Aluminium Pulley
4. Engineering Tec Muffler
5. J's front and rear strut adding more rear X cross bar
6. Adding Oilcooler Gear
I got 17.8 sec for Drag not that much, but I gonna changing Header and some Ignition system including Re-tuning again to get 15-16 sec with Automatic gear.
Need your comments, thanks......
Old Jul 31, 2009 | 12:12 AM
polaski's Avatar
16s, maybe but you have a ways to go. You're leveling off at about 98ps (that 107ps at the vtec transition is an outlier, it's virtually an instantaneous thing and not a good basis for how the car's going to perform), and with the weight and my limited knowledge I'd estimate you can get it down to a low 17 high 16. I'd guess you're trapping in the mid 70s (uhhh that's what, 120km/hr or so). 15 sec times aren't going to happen unless you can sustain over 130ps, or lose a lot of weight. Bench racing don't count for squat though in real life so have fun and good luck.
Still, that's roughly 96 whp on an automatic and that's not too bad.
What a funky design for a muffler!
Old Aug 21, 2009 | 05:45 PM
ev8siv3's Avatar
Do you have a higher resolution picture of the inside of the GE8 ecu? I'd like to know what the Microchip you have the wires hooked into is on the right there.
Old Aug 27, 2009 | 06:59 AM
fluid's Avatar
Is it OK?
Old Aug 27, 2009 | 10:10 AM
ev8siv3's Avatar
Still too small to make out what is on the chip. Do you have something that is 1600x1200 or larger? Was the barcode/label on that chip when you pulled the cover off the ECU?
Old Aug 27, 2009 | 05:04 PM
fluid's Avatar
I don't have it, so sorry about that. I have only this.
Old Aug 27, 2009 | 05:22 PM
ev8siv3's Avatar
Thats much better thanks. Do you happen to know what EEProm chip that is?
Old Aug 28, 2009 | 10:42 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
dam thats nice. i wish we could hook up our ecu's like that.
Old Aug 30, 2009 | 04:59 PM
fluid's Avatar
show my car
Old Sep 11, 2009 | 12:04 PM
ev8siv3's Avatar
Do you have any hints on how to open the ECU case? It appears to be partially pressed and partially silicone sealed... having a hard time popping it!
Old Sep 12, 2009 | 12:52 PM
fluid's Avatar
It has a Red Silicone Seal, you have to use some spray to release it and have to use your force to open it, too.
Old Sep 12, 2009 | 04:46 PM
ev8siv3's Avatar
What brand/type of spray? Can it be re-sealed properly?
Old Sep 21, 2009 | 08:42 PM
fluid's Avatar
Permatex, It can seal with the standard silicone (red one).
Old Sep 21, 2009 | 08:45 PM
fluid's Avatar
update my Miracle Cross Bar for Jazz GE
Old Nov 20, 2009 | 04:28 AM
KL-Jazzer's Avatar
was it tuning on dyno dynamic?
Old Dec 2, 2009 | 10:26 AM
blurblur's Avatar
hi care to share the parts number for the wilwood brake kit (bracket+caliper+disc).
looking at upgrading my brake as well.
Old Feb 20, 2010 | 12:36 PM
Tuned-R's Avatar
Hi, How much to reflash with the Piasini?
What are the setting alteration done..ignition, injector duty%, rev limit, speed cut?
I am in Malaysia driving Thailand made GE8 Auto 5 speed and am interested to do the same.
T-R
MyFitSport10
Jun 16, 2023 09:59 AM
mikejet
15
Jun 16, 2023 09:58 AM
solbrothers
Mar 1, 2012 03:23 AM
TOOL
Jun 3, 2009 12:38 AM
Sid 6.7
Oct 1, 2008 06:39 PM
