Need to fix front lip
Old Aug 17, 2009 | 08:56 AM
dmagic17's Avatar
So I was driving my gf's 2008 sport and curbed the front lip. Not much scratching or damage but part of the lip sort of came unattached and won't go back in. I snapped a cell phone pic of the damage. Any ideas how to reattach? It looks like theres a screw in there but it would be impossible to tighten it if you have lip against the bumper.
Old Aug 17, 2009 | 10:04 AM
binaryh4x's Avatar
Maybe some 3m mounting tape?
Old Aug 17, 2009 | 10:08 AM
dmagic17's Avatar
I was thinking that, but I'd have to get the screw out somehow because it would prevent from being able to push the lip against the bumper. Perhaps a magnetic screwdriver.
Old Aug 17, 2009 | 03:34 PM
i would remove a good section off the bumper and just reinstall.
Old Aug 17, 2009 | 03:40 PM
dmagic17's Avatar
But that's the thing. I dont understand how you can tighten that screw inside there with the lip pushed all the way against the bumper.
Old Aug 17, 2009 | 03:42 PM
no access through the skid plate and fender liner area where it attaches to the front part of the bumper? it might just be a tab that came out and now binding.
do you have a pict further away from the car?
Old Aug 17, 2009 | 04:05 PM
dmagic17's Avatar
Closer Up...
Further back...
Old Aug 17, 2009 | 04:09 PM
so it looks like the tab just cracked open and left your screw where it was bolted on (?). you sure you haven't looked at it from under the car? i'd take my right angle driver and see if i can remove that screw from under the car.
ghetto way (which might scratch the bumper) is to wedge it, remove the screw, and then use 3M tape to close the opening.
Old Aug 17, 2009 | 04:16 PM
dmagic17's Avatar
I'll take another look at it from underneath. Thanks for your help.
Old Aug 17, 2009 | 04:42 PM
binaryh4x's Avatar
I checked under my car and that newest pic definatly makes me think that your "screw" is a rivet.
I would get a long flat head screw driver and try to pry up half of the broken tab, then push the lip back and tape.
Old Aug 18, 2009 | 03:19 PM
yep, you might be able to align the cracked braket to the screw and push it in (?)
how did it go, dmagic?
Old Aug 18, 2009 | 03:22 PM
dmagic17's Avatar
Haven't had a chance to take a look yet. Ill let you know when I do.
Old Aug 22, 2009 | 04:14 PM
Steeldog's Avatar
Hey Man,
You have the same problem I have. You have bent a clip or possibly two. Take it to a body shop that regularly does Hondas (they will have the right clips). It will not cost much. Those funky clips under there have a metal part that has gotten bent, probably when you backed OFF the curb. This exact same thing happened to me. I am just living with it; nobody notices it. When I have to take off the bumper cover, like maybe to install a louder horn, I'll take care of the lip issue. Hell, it isn't really an issue.
By the way, two-sided tape will not hold it. And for God's sake, don't put a screw in there.
If you decide to fool with it any more, please let us know how you came out.
t3chnine
Aug 24, 2011 12:50 AM
xonexlifex
Mar 25, 2010 06:33 PM
chinkyy
Dec 8, 2009 01:47 PM
NostalgicFit
Sep 12, 2008 04:34 AM
iheartmyGD3
May 11, 2007 02:21 PM
