Quarter mile time for a stock Fit??
Old Jul 24, 2006 | 12:33 PM
forester_007's Avatar
How much does a stock Fit do on the drag strip, just want to know my friends Fit did 17.9 on the track with a Manual Tranny. He is a regular driver.
Old Jul 24, 2006 | 12:49 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
sounds about right.. 17 on a stock MT.. prolly like.. 18 or 19 on an AT
Old Jul 24, 2006 | 12:56 PM
gettinafit's Avatar
If he was a drag racer and had sticky tires! Heat em up, then we'l get the true readings! Should be 16.6 in 1/4 for M/T!
Old Jul 24, 2006 | 07:18 PM
revs to 9's Avatar
Honda Fit Forums Moderator
i've quarter miled mine, MT sport, and i've only gotten down to 17.76. i'm not the best driver out there, but felt it was a pretty good run.
Old Jul 24, 2006 | 07:28 PM
garett's Avatar
i havent had the chance to drive one of these yet, but i cant imagine there being enough power that it would need special tires to keep from breaking loose. i think 16.6 is unrealistic. maybe if you are an incredible driver and you are at the right elevation and it is a really really cold night.
Old Jul 24, 2006 | 09:11 PM
fit_4_a_king's Avatar
I've tried about 50 runs down the strip already and the best I could muster is 17.1@79mph. I checked Car&Driver and they were able to pull a 16.8.
Old Jul 24, 2006 | 11:44 PM
gettinafit's Avatar
I haven't gotten to the track yet, but i believe that a 16 second pass is attainable! Especially since i've read car and driver and other import runs of the Fit 1.5 vtec running 16.6 and 16.9 respectively!
From my past experiences running on a Dragstrip, b/c of all the rubber and the burnouts, a high rpm launch (to get the car out of dead low end torque-less boundaries) of lets say 5500 rpms will cause wheel slippage and less acceleration down the track at the same time!
Using even at least DOT approved street drag radials like nittos 555r or BFG's and heating them up REAL good will give you the traction you are looking for out of that high RPM launch and thus proving for a better time! Definately A Dramatic Difference!
Just try it! You'll drop .5 sec!
Old Jul 25, 2006 | 01:00 AM
garett's Avatar
you know what, you are right. i wasnt even thinking about the track itself being slick. but i still think 16.6 consistantly will be a rarity. if you can do it consistant, then you are just good
Old Jul 25, 2006 | 01:51 AM
Mellow Yellow's Avatar
According to C&D, 16.7 for the MT, 17.8 for the auto.
Old Jul 25, 2006 | 02:23 AM
hiroko12's Avatar
Slow. This is a 1.5 liter engine fellows.
Old Jul 25, 2006 | 09:16 AM
sLiVeRwOrM's Avatar
Its only a 1.5L for alittle longer! N1 will have us out a swap kit in the near future.. hehe!
Old Jul 26, 2006 | 10:03 AM
blackgd3's Avatar
Senior Member
Yeah! Any news from them?
Old Jul 26, 2006 | 11:44 AM
gettinafit's Avatar
Well Any time in the 16's is Good!
Old Jul 26, 2006 | 11:57 AM
smeister's Avatar
17s
I am going to try to hit the 17s at Orlando Speedway hopefully this Friday. It seems they have stopped dragging stock cars on Wednesday. I'll keep you guys updated. Wish me LUCK!
Old Jul 26, 2006 | 12:57 PM
gettinafit's Avatar
good luck!!
Old Jul 28, 2006 | 11:49 AM
Super Spoon's Avatar
What would a lightened 1.3 do on a 1/4 mile ???
Old Jul 28, 2006 | 11:07 PM
smeister's Avatar
time
The fastest time was a 17.3 with a 2.4 60's on everything stock Base Fit at Orlando Speed World Dragway. That's sea level and around 80F outside.
I think 16.8 that Car and Driver tested is attainable with better tires, driving, and dragstrip (Edited: AND cooler outside temps and sea level).
I am sure someone can run even lower than 16.8 in ideal conditions just not me.
Old Jul 28, 2006 | 11:18 PM
My Fit is a Spoon Replica but with only a 1300 i-dsi engine. You can check
out the pix at pics and video threads.
I took out the ULT seats and replaced the front seats with light weight
kevlar bucket seats. Made minimal mods like spoon drop in filter, replaced
the cat with a test pipe and replaced the stock muff with a spoon n1 bolt
on muff. So far the car improved on performance. But yet to run it on legal
drag events.
I'm now in the stage of getting a big bore throttle body and replacing the
stock pipings to a bigger outside diameter (2 inches).
I wanna have a go with a NA 1.5 VTEC fit. To see how my fit compares.
Keep you all posted
Old Aug 1, 2006 | 06:55 PM
shuttle's Avatar
i have a fit dx manual and i do 16.7 at 80 mph and later i strip the rear of my fit i do 16.301 at 82 mph with 2.222 of 60 feat.
Old Aug 1, 2006 | 09:25 PM
Those are great times! How are you launching and at what RPM? AS you can see from my previous post, I could not get a 60 ft below 2.4
